hello everyone
Does anyone having trouble to clean Beovision screen from handprint?
I also have same problem.
My dealer say "Do not use widow cleaner" because coating will came off.
What is the best way to clean the screen of TV.
https://www.instagram.com/p/BUBhzKVArBD/
I find just a damp cloth and then a clean duster - and a lot of hard work!
I find just a damp cloth and then a clean duster - and a lot of hard work - at least that is the case with a BV6-26 and my old Avant - not sure about the new ones, but I would definitely not use household detergent.
tnks for kind answer andrew
thank you michael
just ordered soft cloth from internet
thank you
I ordered this one from Internet cost me usd 20
I will try with soft cloth
