Cleaning Beovision avant screen
38000ft
Posts 14
38000ft Posted: Thu, Jun 1 2017 7:06 AM
hello everyone
Does anyone having trouble to clean Beovision screen from handprint?
I also have same problem.
My dealer say "Do not use widow cleaner" because coating will came off.
What is the best way to clean the screen of TV.
https://www.instagram.com/p/BUBhzKVArBD/
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Jun 1 2017 9:14 AM
I find just a damp cloth and then a clean duster - and a lot of hard work!
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Jun 1 2017 9:15 AM
I find just a damp cloth and then a clean duster - and a lot of hard work - at least that is the case with a BV6-26 and my old Avant - not sure about the new ones, but I would definitely not use household detergent.
38000ft
Posts 14
38000ft replied on Fri, Jun 9 2017 5:29 AM
tnks for kind answer andrew
Aussie Michael
Melbourne, AU
Posts 3,730
I always find that some dishwashing liquid with COLD water is the best
Don't use warm water it won't stop streaking.
Then dry with a soft cloth
w5bno123
London
Posts 578
w5bno123 replied on Fri, Jun 9 2017 12:09 PM
Hi
The best product we have found that works well on all TV screens is Fast Glass by Auto Glym. Spray a small amount on screen or microfibre eco cloth and wipe gently away and it takes seconds without leaving any streaks
38000ft
Posts 14
38000ft replied on Mon, Jun 12 2017 10:18 AM
thank you michael
just ordered soft cloth from internet
38000ft
Posts 14
38000ft replied on Mon, Jun 12 2017 10:19 AM
thank you
I ordered this one from Internet cost me usd 20
I will try with soft cloth
thank you
Page 1 of 1 (8 items) | RSS
