Just wanted to share an idea for make up on the grill fabric. I used fabric paint to restore the old black appearance. The paint is from simplyspray.com. A small bottle is just sufficient for a pair of speakers
Hi, an interesting product and option to grill cover restoration versus completely installing new cloth. So the spray coloring absorbs into the old cloth. Do you just wipe any of the spray from the metal trim and was that easy?Thanks,sonavor
hi sorry for late reply. I just put some paint tape, hope it is the right word, on the alu trim and removed it just after painting and wiped small stains of with my fingers immediately after painting.
Hi, just used paint tape and removed it right after painting and wiped small stains left of with my fingers. Paint only stick to cloth.
