S55 grill make up
This post has 3 Replies | 0 Followers
jbj2711
Posts 11
jbj2711 Posted: Tue, Jun 20 2017 10:21 PM
Just wanted to share an idea for make up on the grill fabric. I used fabric paint to restore the old black appearance. The paint is from simplyspray.com. A small bottle is just sufficient for a pair of speakers
sonavor
Texas, United States
Posts 3,732
sonavor replied on Wed, Jun 21 2017 8:19 PM
Hi, an interesting product and option to grill cover restoration versus completely installing new cloth. So the spray coloring absorbs into the old cloth. Do you just wipe any of the spray from the metal trim and was that easy?
Thanks,
sonavor
jbj2711
Posts 11
jbj2711 replied on Sun, Jun 25 2017 6:23 PM
hi sorry for late reply. I just put some paint tape, hope it is the right word, on the alu trim and removed it just after painting and wiped small stains of with my fingers immediately after painting.
jbj2711
Posts 11
jbj2711 replied on Sun, Jun 25 2017 6:24 PM
Hi, just used paint tape and removed it right after painting and wiped small stains left of with my fingers. Paint only stick to cloth.
Page 1 of 1 (4 items) | RSS
