Im talking about the beocord v 8000-mx, for example my sega genesis is plugged into the scart port of the machine and it sems to not display the video signal, do any of you know how? im stil new in the mx series of tv's.
Do you mean that you are wanting to connect an xbox to a Beovision MX8000 tv?
If so,you will need to program the inputs to correspond to commands from say a Beolink 1000 remote control,or a Beo4.
Let us know what you are trying to do?
Nick
Not really, i do mean a sega genesis by a scart plug on the video machine and i have a beo 4 remote, and yes! i am useing a mx 8000 tv
Double post - sorry!
If you want to use the VTAPE/Decoder SCART socket on the V8000 then you probably need to set up one of the TV channels on the VCR as if it needs a DECODER. Selecting this channel will then pass the signal through to the TV.
Alternatively, use a SCART to Composite cable and connect the Sega to the Video In sockets on the back of the V8000. This input is selected by choosing CAMERA from the VCR menu.
