Master Control Panel 5500 repair
Richard
Toledo, Ohio USA
Posts 17
Silver Member
Richard Posted: Thu, Jul 27 2017 3:38 AM
Hello, I know this has probably been beat to death but here goes. My MCP 5500 is exceptionally clean & functional excepting the volume control, which does not work. The ring turns (but has a break) but nothing happens - no lights on MCP or Beomaster 5500. I read in a couple of threads that this indicates a problem with the micro switch. Some suggest a good cleaning & perhaps a little TLC on the contacts & some sewing machine oil will do the trick. The switch looks fine to me but the three pronged springy piece looks to have a problem. The three tips seem to have a tiny piece of felt adhered to them. The tip @ the switch location has lost its felt - saw it was loose & saw it fall off. Should I install new felt tips? Can anyone here detail the extend of disassembly required to completely clean / lubricate / service this switch assembly in order to put it right? I cannot find a service manual here to download. I would add some pictures if I knew how. I have a few other items of concern on various 5500 components but first I need to be able to turn the volume down.:) Thank You all in advance for your help & expertise.
DMacri
United States
Posts 881
DMacri replied on Wed, Aug 2 2017 4:56 AM
I can't figure how to post a link for you from my iPhone, but just enter "MCP volume" in the search bar for some very helpful tips. Good luck.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (2 items) | RSS
