Beo 4
This post has 4 Replies | 0 Followers
Beopip
Posts 3
Beopip Posted: Mon, Aug 28 2017 9:51 PM
Does anyone know how to make BEO 4 control volume when  B&O Overture switched to Aux input. BEO 4 controls all other inputs re volume but not when switched to Aux!
Many thanks.
The Beonic Man
Bristol
Posts 812
Have you tried the different settings in the LIST menu to see if one of them works? Or you could consider reprogramming here too.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Aug 29 2017 8:44 AM
Beopip:
Many thanks.
Presume that you are talking about volume after selecting A.AUX input (audio) with the Beo4, rather than V.AUX input (video)?
Is the Overture linked to any other B&O kit?  If so, you could have a problem with option settings.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Aug 29 2017 11:38 AM
I think so too. Try A.OPT 1 (audio option 1) and select A.AUX - or set your Ouverture to A.OPT 2 and select a video source to open the AUX port
(if it is not masterlinked to a BV as a videomaster.
Stefan
Beopip
Posts 3
Beopip replied on Wed, Aug 30 2017 5:09 PM
Thanks will give it a go!
Page 1 of 1 (5 items) | RSS
