Does anyone know how to make BEO 4 control volume when B&O Overture switched to Aux input. BEO 4 controls all other inputs re volume but not when switched to Aux!
Many thanks.
Have you tried the different settings in the LIST menu to see if one of them works? Or you could consider reprogramming here too.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Beopip: Hi, Does anyone know how to make BEO 4 control volume when B&O Overture switched to Aux input. BEO 4 controls all other inputs re volume but not when switched to Aux! Many thanks.
Presume that you are talking about volume after selecting A.AUX input (audio) with the Beo4, rather than V.AUX input (video)?
Is the Overture linked to any other B&O kit? If so, you could have a problem with option settings.
I think so too. Try A.OPT 1 (audio option 1) and select A.AUX - or set your Ouverture to A.OPT 2 and select a video source to open the AUX port
(if it is not masterlinked to a BV as a videomaster.
Stefan
Thanks will give it a go!
