Bind L-A.AUX to button
This post has 1 Reply | 0 Followers
alfamadorian
Posts 2
alfamadorian Posted: Sun, Oct 1 2017 3:27 PM
Is it possible to assign a key on the Beo 4 for L-A.AUX?
If not, can I use a newer remote control to achive this?
I have a BeoSound 4
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Oct 1 2017 3:45 PM
It's not possible with Beo4.  You could put the Beo4 in permanent LINK mode but that doesn't reduce the number of button presses.
Might be possible with Beoremote 1 - others will know.
What (and where in your system) are you trying to control?  There may be another way to achieve the desired result.
(EDIT:  I presume that you currently have L-A.AUX accessed through LIST?)
Page 1 of 1 (2 items) | RSS
