Is it possible to assign a key on the Beo 4 for L-A.AUX?
If not, can I use a newer remote control to achive this?
I have a BeoSound 4
It's not possible with Beo4. You could put the Beo4 in permanent LINK mode but that doesn't reduce the number of button presses.
Might be possible with Beoremote 1 - others will know.
What (and where in your system) are you trying to control? There may be another way to achieve the desired result.
(EDIT: I presume that you currently have L-A.AUX accessed through LIST?)
