Hi all!
I have a BE conected to my imac either line in or airplay.
Both ways it seems that the maximum volume is less than I achieved with my BL4000's conected directly to imac (usb dac - powerlink cables - line).
Am I wrong? anybody shares this feeling?
I mention that I set up BE to "maximum".
I mentioned that I did it.
anyone with a BE can share his/her's experience?
And did you adjust the volume on the iMac, too?
of course
I have a similar problem. Little too low max volume, even if set to max in BeoSetup settings, after update 2015-04-27. Asked the dealer week after but no answer.:-/
Thanks for quick answer. I dont remember, just followed the instructions in the update. Is it just to try that now without other problems ? :-)
Someone who knows? Is it just to press reset after update, without complications?
Because a reset is a reset. To what, to the original firmware? I dont want that back, because its horrible.
I have read the instructions, and i cant interpret it your way.
Just because there is a button I dont have to press it like a child.
Difficult?
ThomasE:Because a reset is a reset. To what, to the original firmware? I dont want that back, because its horrible. I have read the instructions, and i cant interpret it your way. Just because there is a button I dont have to press it like a child. Difficult?
It was solved by pulling the power plug
Ps. "Line-in" on Android Beomusic app (2015-05-18) still does not work. But on Ios it does. Ds.
Having same issues but no software update available
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
