Beosound Essence volume
This post has 17 Replies | 2 Followers
liviu_o
Posts 157
liviu_o Posted: Mon, Jun 8 2015 4:34 PM
Hi all!
I have a BE conected to my imac either line in or airplay.
Both ways it seems that the maximum volume is less than I achieved with my BL4000's conected directly to imac (usb dac - powerlink cables - line).
Am I wrong? anybody shares this feeling?
I mention that I set up BE to "maximum".
CB
> You are Here <
Posts 1,762
CB replied on Mon, Jun 8 2015 8:53 PM
liviu_o
Posts 157
liviu_o replied on Tue, Jun 9 2015 9:18 PM
I mentioned that I did it.
anyone with a BE can share his/her's experience?
liviu_o
Posts 157
liviu_o
Posts 157
TWG
Posts 1,672
TWG replied on Wed, Jun 10 2015 8:31 AM
And did you adjust the volume on the iMac, too?
liviu_o
Posts 157
liviu_o replied on Fri, Jun 12 2015 2:19 PM
of course Smile
liviu_o
Posts 157
of course Smile
ThomasE
Posts 6
ThomasE replied on Fri, Jun 12 2015 3:31 PM
I have a similar problem. Little too low max volume, even if set to max in BeoSetup settings, after update 2015-04-27. Asked the dealer week after but no answer.:-/
ThomasE
Posts 6
CB
> You are Here <
Posts 1,762
CB replied on Fri, Jun 12 2015 5:46 PM
ThomasE
Posts 6
ThomasE replied on Fri, Jun 12 2015 11:56 PM
Thanks for quick answer. I dont remember, just followed the instructions in the update. Is it just to try that now without other problems ? :-)
ThomasE
Posts 6
ThomasE replied on Tue, Jun 23 2015 11:13 AM
Someone who knows? Is it just to press reset after update, without complications?
CB
> You are Here <
Posts 1,762
CB replied on Tue, Jun 23 2015 8:54 PM
ThomasE
Posts 6
ThomasE replied on Wed, Jun 24 2015 7:58 PM
Because a reset is a reset. To what, to the original firmware? I dont want that back, because its horrible.
I have read the instructions, and i cant interpret it your way.
Just because there is a button I dont have to press it like a child.
Difficult?
vlohjr1
Posts 553
vlohjr1 replied on Wed, Jun 24 2015 8:18 PM
ThomasE:
Difficult?
Had the same problem. Updated the software and all issue solved. Easy as 123Smile reset should do the trick
ThomasE
Posts 6
ThomasE replied on Wed, Aug 12 2015 9:47 PM
It was solved by pulling the power plug Stick out tongue
Ps. "Line-in" on Android Beomusic app (2015-05-18) still does not work. But on Ios it does. Ds.
Chris Harrison
Peak District
Posts 381
Having same issues but no software update available
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Page 1 of 1 (18 items) | RSS
