Beocord V8000 videorecorder recording option??
This post has 6 Replies | 0 Followers
Dirk
Netherlands
Posts 10
Dirk Posted: Wed, Dec 13 2017 8:24 PM
Hello,
I have (still) a Beocord V8000 videorecorder.
How can I manually make a recording  WITHOUT any remote.!
As it seems there is ( among other)  a PLAY button on the recorder but NOT a Record button.
Dirk
Steffen
Denmark
Posts 1,408
Steffen replied on Wed, Dec 13 2017 8:33 PM
You're right - there is no Record button. So you'll have to use a remote (and Beovision).
Dirk
Netherlands
Posts 10
Dirk replied on Wed, Dec 13 2017 10:05 PM
So when I have a remote Beo4  or Beolink 1000 , I still need a Beovision TV set.?
It wil not work on a other brand TV   like Sony, Philips, Panasonic and other NON B&O  tv-sets?
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Dec 14 2017 7:56 AM
Dirk:
Unfortunately that is correct.
However, if you take the top off the V8000 there is a small short range IR receiver on the top left of the chassis that will accept commands direct from a B&O remote.  It is normally used for IRSS (IR Service Software) control, but I believe it would also allow you to select normal functions such as play and record, albeit from very short range, and with the set partially dismantled!
Dirk
Netherlands
Posts 10
Dirk replied on Sat, Dec 16 2017 8:14 AM
I will try this.... thank you
Guy
Warwickshire
Posts 2,590
Guy replied on Sat, Dec 16 2017 8:22 AM
The IR sensor is a little tricky to find!  It's on the top right hand side of a vertically orientated module to the left of the tape mechanism.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 17 2017 9:12 AM
Why not just get another VCR on ebay - I take it is to play back something treasured? Sell the V8000 and you will get more than it costs to get a VCR that works without dismantling it!! The V8000 is just a Philips anyway! If you had a VX5000, it would be different, but that has a record button on it anyway!!
Peter
Page 1 of 1 (7 items) | RSS
