since the update to firmware 1.15 I have a few problems with my Beosound 35 devices. When I start up the BS 35, I hear a crackling sound and sometimes the WLAN Connection is lost.
Is there a possibility to download the 1.14 version of the software. With this version I never had these problems.
Mirco
If you contact your dealer they can request product support release a software roll back for your serial number. This hasn't been done globally as not all speakers are effected. The regression of software will loose a few new features but should make wireless connection more stable.
Regards
Opman
