Hello Beoworlders
my BV7 MK3 is not switching on anymore
the RED standby light appears but nothing else
i have used different commands on the BEO4 and disc tray bit nothing happens
I have unpluged it from mains and that does not work did not even ask for a PIN code
any ideas would be appreciated
Start by checking the obvious, -the BEO4
If its sending codes, you should be able to see the two IR diodes as two small purple dots with a digital camera.
Volume up/down will send codes continuously as long as the key is pressed.
