BV7 MK3 Red light
quader
Posts 109
quader Posted: Wed, Feb 14 2018 12:37 PM
Hello Beoworlders
my BV7 MK3 is not switching on anymore
the RED standby light appears but nothing else
i have used different commands on the BEO4 and disc tray bit nothing happens
I have unpluged it from mains and that does not work did not even ask for a PIN code
any ideas would be appreciated
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Wed, Feb 14 2018 5:54 PM
Start by checking the obvious, -the BEO4
If its sending codes, you should be able to see the two IR diodes as two small purple dots with a digital camera.
Volume up/down will send codes continuously as long as the key is pressed.
Page 1 of 1 (2 items) | RSS
