I need a recommendation on how to remove screw "B" that adjusts the tonearm height.
The arm provides just enough clearance to play perfectly flat older (thinner) records.
The slightest warp or 180-gram vinyl exceeds the clearance.
The screw head is damaged (got it that way) and I cannot adjust the height.
Are there any tools/methods you recommend to remove or loosen the screw so that I can try to adjust the arm? The hole opening for the screw is very tiny and I haven't found a way yet.
Are there replacement parts that I could try to get?
Thanks,
Jorge
Thanks for the tip, Chris.
I didn't see anything out of place when I opened the TT.
I'll take a closer look. Is the position around that rail adjustable?
-Jorge
