Beogram 6500 tonearm height adjustment
This post has 3 Replies | 2 Followers
jgrilo
Posts 10
jgrilo Posted: Sun, Feb 25 2018 5:23 PM
I need a recommendation on how to remove screw "B" that adjusts the tonearm height.
The arm provides just enough clearance to play perfectly flat older (thinner) records.
The slightest warp or 180-gram vinyl exceeds the clearance.
The screw head is damaged (got it that way) and I cannot adjust the height.
Are there any tools/methods you recommend to remove or loosen the screw so that I can try to adjust the arm? The hole opening for the screw is very tiny and I haven't found a way yet.
Are there replacement parts that I could try to get?
Thanks,
Jorge
ProGram
59269 Beckum, Germany
Posts 383
ProGram replied on Tue, Feb 27 2018 8:14 AM
Hi, is it possible that the rear one of the tonearm slider rails has loosened and therefore the tonearm is no longer parallel to the cabinet (in cueing position)?
Chris
jgrilo
Posts 10
jgrilo replied on Tue, Feb 27 2018 5:40 PM
Thanks for the tip, Chris.
I didn't see anything out of place when I opened the TT.
I'll take a closer look. Is the position around that rail adjustable?
Thanks,
-Jorge
ProGram
Posts 383
ProGram replied on Wed, Feb 28 2018 8:13 AM
The „rail“ is a metal rod, which is normally clamped on the sub-chassis. It is not adjustable. Strictly speaking, there are 2 of those rods.
Page 1 of 1 (4 items) | RSS
