hi all,
I have a BLGW which I am just getting started with programming and setting up, but am stuck with RS232 programming. I have a V1 which is set up for a matrix but as I don't own an atlona I can not control via puc, so I am looking at controlling my HDanywhere matrix via RS232.
What I am trying to achieve is when I press say DTV on my beo 4, my V1 selects dtv and the BLGW then sends an RS232 command to the matrix to tell it to turn on output 1 hdmi 1 (BABABFC60401008A) via USB to RS232 cable.
if some one can tell me how to start I can hopefully work out the rest.
thanks
Toby
You might want to start here:
http://www.lintronic.dk/AppNote_MasterLinkGateway.pdf
https://beointegration.wordpress.com/
1:BV7+BL7.1+BS4+BL6000+BV6+BL2000+MLGW+Beo4
2:BV7+BL7.4+BL3500+BM5+BL3+Lutron GE/Sivoia QS+HikVision+Dune+LinTronic+BLGW+Beo4+Beo5+Essence remote+BeoTime+BeoLinkPC+BL4+KNX+... BeoMaster900
Use the MLGW protocol to send strings. I use it via tcp/ip but should be exactly the same for serial
http://mlgw.bang-olufsen.dk/source/documents/mlgw_2.24b/
