Hi all,
I wonder if you can assist me with the mysteries of the OPTION settings.
I recently changed my beloved Beovision 3-32 with a BV 7-40 Mk IV (without Bluray) and suddenly I found myself messing up the OPT settings for the rest of my gear:
I have a Beocenter 2300 and Beogram 3300 connected to the TV via Masterlink ( I set A.OPT to 0 and I can now control CD, Radio and get the sound from the Beogram (but can't change track etc. like I used to)The Beogram is assigned to the button A.MEM which translates to PHONO on the Beocenter display and on the side-display of the 7-40 it says N-RADIO ( which I assume is correct)
I also have a DVD 2, that is now connected via HDMI only ( I tried scart also with same result) I get the picture of the DVD if I start it by putting on a DVD, but cannot control anything or even start the DVD 2 with the BEO 4. I have assigned DVD2 to the button DVD. I have currently V.OPT set to 2 ( but I have tried almost all of them without luck)
Any ideas what I am doing wrong?
Peter
---------------------------------------------------------------------------------------------------------------------------------Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000, Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Hi Peter.
As far as the issues with the DVD2 goes, if I remember correctly you have to connect to the TV with the scart cable too as the cable carries the signals to control the DVD player.
Stoobie
Thanks Guys!
@Stoobietoo; I was naive to think i could have just a HDMI cable attached.. I followed your advice and now I have both HDMI and SCART... and it works like a charm..even though I hate the cable clutter..
@w5bno123: so, if I understand you correctly, I should keep A.OPT as 0 and then set V.OPT as 4 ( to be able to control also the Beogram, am I correct?
Peter:Thanks Guys! @Stoobietoo; I was naive to think i could have just a HDMI cable attached.. I followed your advice and now I have both HDMI and SCART... and it works like a charm..even though I hate the cable clutter.. @w5bno123: so, if I understand you correctly, I should keep A.OPT as 0 and then set V.OPT as 4 ( to be able to control also the Beogram, am I correct? Thanks Peter --------------------------------------------------------------------------------------------------------------------------------- Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000, Beocenter 2300, 9000, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Peter: I was naive to think I could have just a HDMI cable attached..
Not naive Peter almost all other DVD players have a built in IR eye, the DVD 2 doesn't. But at least it is working.
Good luck with setting the options too.
Thanks w5bno123, for the assistance!
It seems to work fine now!
All the best,
