Beocenter 9000 Speakers 1 Control
leafrancis
Posts 4
Silver Member
leafrancis Posted: Fri, Mar 23 2018 6:09 PM
Can anybody tell me how to enable and disable Speakers 1 output on a Beocenter 9000? At the moment they are OFF. I know that they will be turned off when headphones are plugged in, as the jack plug socket shorts the relay drive, but I notice that there is also a transistor that can control the Speakers 1 relay, but no idea how to control it.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi leafrancis,
Pressing the MUTE button on the 9000 will disable the Speakers 1 output, but leave the Speakers 2 output playing.  The red MUTE light will show in the display.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
leafrancis
Posts 4
Silver Member
Thank you Steve for your advice. The MUTE button definitely operates the MUTING relay as I can hear it, but still no output on SPEAKER 1 sockets. This also removes the possibility that the headphone jack is holding the relay open permanently. I will now look more closely at the MUTING relay, as it could possibly be faulty, although I would have thought unlikely on both LEFT and RIGHT.
Thanks again.
Tony
Guy
Warwickshire
Posts 2,590
Guy replied on Mon, Apr 2 2018 9:31 AM
Just a thought - are you sure that there isn't a 1/4 inch to 3.5mm adaptor in the headphone socket?  The BC9000 has a 1/4 inch headphone socket, but others have failed to notice that an adaptor has been left inside for the more common 3.5mm headphone plug.
Otherwise yes the relay is probably faulty.  I assume Spkr2 works well?
Page 1 of 1 (4 items) | RSS
