Hello,
Trying to figure out an issue with a digital tv desk top box, I had to switch off and on the V1 repeatedly.
After doing this 2 or three times in a row, the V1 no longer responds to the remote and remains off. After a couple of minutes it responds again.
Anyone else have this problem too?
Is this a bug or some sort of protection mechanism?
H.
The symptom similar to your description has been reported to B&O by at least one UK dealer.
No real conclusion was found, but the fault apparently disappeared after a non related software update.
Regards Keith....
I remember this from setting up both mine and a friends V1. The easiest thing was to unplug it and plug it in again. Havent had the problem since, seems to be related to several power on/off in a short period of time.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
