Preamp
Mike
NE Ohio USA
Posts 10
Mike Posted: Tue, May 1 2018 5:15 PM
I think some of the vintage B&O amplifiers can be used as a preamp to drive a large amp. Does anyone have suggestion of which amp has the capability of being a preamp and which one would be the best? I’m looking to drive JBL L7’s with a 200w B&K 2 channel power amp.
Saint Beogrowler
Saint Paul
Posts 780
usamike10:
Cheapest best option is probably the Beomaster 5000 which has a pre-out that is not attenuated. It will give you 3 line inputs plus a phono stage. Plus the remote is cool.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi usamike10,
Welcome to Beoworld!
As well as the Beomaster 5000 which Saint Beogrowler mentioned, any B&O music system with Powerlink sockets (ie. anything from around 1990 onwards) can be used as a pre-amp to drive a regular power amp by adding this cable to one of the Powerlink outputs:-
https://soundsheavenly.com/bang-olufsen/5-pin-din-to-twin-rca-powerlink-compatible-to-non-bo-hifi-amplifier-receiver-etc-din-to-twin-phono
This gives you a huge range of choices, including Beomasters 3500, 4500, 6500, 7000, Beocenters 2, 9300, 9500, Beosounds 3000, Ouverture, 3200, 4, 9000, Beomaster 5, etc. with full control from the B&O remote.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Mike
NE Ohio USA
Posts 10
Mike replied on Wed, May 2 2018 6:51 PM
Wow, thank you both! I’m just discovering all this cool B&O stuff, I hope it sounds as good as it looks.
Page 1 of 1 (4 items) | RSS
