Beocenter 1 - Apple TV
This post has 4 Replies | 2 Followers
bbrlq02
Posts 3
bbrlq02 Posted: Thu, Sep 27 2012 11:15 AM
I want to connect a 1st generation Apple TV to my BeoCenter 1 using a SCART input on the rear.  I know that I can buy a cable to plug into the 3 component video out and 2 audio out sockets on the ATV with a SCART socket on the other end to plug into the Beocenter 1.
The questions is will the Beocenter accept the component video signal?
kai
Posts 362
kai replied on Thu, Sep 27 2012 11:20 AM
Hi
No I'm afraid that wont work you need either buy a convertor or jailbreak the atv this gives the option to output in composite which the beovision 1 can display
bbrlq02
Posts 3
bbrlq02 replied on Thu, Sep 27 2012 3:36 PM
Thanks kai.  So could I also use a HDMI to composite SCART converter?
bbrlq02
Posts 3
Stoobietoo
Exeter, Devon, UK
Posts 692
This link may help
http://archivedarchivedforum2.beoworld.org/forums/p/41961/348119.aspx#348119
Although it was dealing with an ATV1 and BS2 it applies to ATV1 and any scart connection to a TV.
Stoobie
Page 1 of 1 (5 items) | RSS
