I want to connect a 1st generation Apple TV to my BeoCenter 1 using a SCART input on the rear. I know that I can buy a cable to plug into the 3 component video out and 2 audio out sockets on the ATV with a SCART socket on the other end to plug into the Beocenter 1.
The questions is will the Beocenter accept the component video signal?
Thanks kai. So could I also use a HDMI to composite SCART converter?
This link may help
http://archivedarchivedforum2.beoworld.org/forums/p/41961/348119.aspx#348119
Although it was dealing with an ATV1 and BS2 it applies to ATV1 and any scart connection to a TV.
Stoobie
