I recently re-capped my Beocenter 9000 and also upgraded a few of the opamps as well as restored the CD operation. It is a wonderful piece of engineering. As part of this exercise I got more deeply into the operation of the unit.
I have a technical operation question. When selecting "AUX" the numbers 1 2 3 4 5 8 appear across the top LED display. Selecting AUX-8 will use the Microphone input, this is described in the users manual.
The Beocenter 9000 will also allow selection of AUX 1 through 5. Does anyone know what selecting AUX 1 through 5 does?
George Werl
The other AUX options relate to the situation where your Beocenter is in A.OPT2 and connected to compatible B&O VIDEO equipment via the AUX socket, as follows:
AUX 1 - TV
AUX 2 - V.TAPE
AUX 3 - SAT (or DTV)
AUX 4 - CDV (or DVD)
AUX 5 - V.TAPE.2
This enables you to select the above options using the Beocenter's front panel, rather than a remote.
And welcome to Beoworld, by the way, especially as a 'Gold' member!!
Hey George,
Welcome!
How's the sound improvement on your machine?
Menahem
