BeoNut since '75
Strange indeed !
The last update was June 13
Version 1.17.23091.157086471
So, it was updated recently...
An other possibility is that I activated something in the Beo4 without knowing (I was « playing » with the hidden buttons)
EDIT: this is it !
From http://bogo.custhelp.com
How do I activate sources using BeoRemote One or Beo4?
To use Beo4, you must set the audio system in A.OPT 1.
—> A.Opt set to 0 solved my problem (and pressing Radio still starts the BL5)
Have to say that these Beo4 options are not clearly explained...
