Beosound 35 and Beo4 ?!?
This post has 3 Replies | 0 Followers
CB
> You are Here <
Posts 1,762
CB Posted: Sat, Jun 30 2018 6:19 PM
Hi everybody
Till then I used an Essence remote to control the BS35 and a Beo4 to control my BL5s (start by pressing the Radio button), but today pressing the Radio button also started TuneIn on my BS35 ?!?
So I tried other buttons of the Beo4, and all works:
TuneIn = Radio or N-Radio
Line-In = A.Aux
QPlay = A.Mem2
Spotify = CD
Music = A.Mem
Etc.
This seems new to me...
Now I have a problem: pressing the Radio button is supposed to start only my BL5s...
I think I can change their mode to avoid this (something with the Shift button, but I’m not sure)
Any help is welcomed Smile
elephant
AU
Posts 8,219
elephant replied on Sun, Jul 1 2018 12:29 PM
Strange !
I mean it is working as intended ... but what changed ?
An essence update seems reasonable.
But a BS35 OTA update without you knowing ???
Doesn’t seem likely.
BeoNut since '75
CB
> You are Here <
Posts 1,762
CB replied on Sun, Jul 1 2018 1:56 PM
Strange indeed !
The last update was June 13
Version 1.17.23091.157086471
So, it was updated recently...
An other possibility is that I activated something in the Beo4 without knowing (I was « playing » with the hidden buttons)
EDIT: this is it !
From http://bogo.custhelp.com
How do I activate sources using BeoRemote One or Beo4?
To use Beo4, you must set the audio system in A.OPT 1.
—> A.Opt set to 0 solved my problem Smile(and pressing Radio still starts the BL5)
Have to say that these Beo4 options are not clearly explained...
elephant
AU
Posts 8,219
elephant replied on Tue, Jul 3 2018 11:34 AM
Yes - thumbs up
BeoNut since '75
Page 1 of 1 (4 items) | RSS
