VLC-player from mac on BV11 only back surround
This post has 12 Replies | 0 Followers
Master123456789
Posts 237
Master123456789 Posted: Sun, Apr 15 2018 9:06 AM
Dear forum
When I play a movie on my mac on VLC-player to my Beovision 11 via a HDMI-cable I get the surround-back sound on my BV11. When I use another player on my mac it is not a problem. What to do? I only have the tv-speakers and no surround setup. That is also why it is very strange.
Hiort
Sweden
Posts 2,895
Hiort replied on Sun, Apr 15 2018 9:18 AM
Master123456789:
Dear forum
Check how the speakers are configured for the source that is configured for that hdmi.
Could be that the tv speakers are configured as surround l/r
Master123456789
Posts 237
I have also checked up on that. They are front left and right. When I use another player, example quicktime it is no problem. But I want to use VLC as it can add subtitles, the srt file
Master123456789
Posts 237
Nobody uses VLC player from mac to HDMI? ;-) ;-)
elephant
AU
Posts 8,219
elephant replied on Sat, May 5 2018 10:27 AM
Master123456789:
I could :)
I have all the bits and pieces in place but I have never done it (except maybe years ago as a test :-)
What movie are you trying to watch ?
If it’s not a bootlegged copy I could try a test for you !
BeoNut since '75
Master123456789
Posts 237
try to test a blue ray or dvd movie :) I have just tried on my BV 8-40 - no problem, it worked - so it must be something on my BV11
elephant
AU
Posts 8,219
Master123456789:
Oh well - I have a 8-40 too, so my test is redundant ... although I must say I don’t think I have ever used VLC for physical media !
I suggest we now try to think of ways in which your two BVs could be so different as to create what seems to be a bug ...
BeoNut since '75
elephant
AU
Posts 8,219
Master123456789:
I though a BR drive on a MacMini was “a bag of hurt” and was not supported ... or did things change ?
BeoNut since '75
Master123456789
Posts 237
I just received an update to VLC-player and now the sound on my BV11 is one front speaker and one back. I also tried with separate speakers - did not make any difference.
lawrencejmcook
Posts 742
Hi - I have the same issue playing 5.1 movies on VLC with my Mac mini and my BV9.
In older versions of VLC I used to be able to press (I think) CMD-L and change the soundtrack being played. I would repeat that until I got to the one that was giving trouble and it would resolve it. But that work-around stopped working a couple of versions ago.
I tried playing with the plethora of settings, but without success.
I gave up and started using Kodi (or whatever it’s current name is). Works beautifully, but I never got to grips with the library function.
Master123456789
Posts 237
I am open till trying another mediaplayer. Kodi cannot be verified on my mac,  it is from an "unidentified developer" - got other alternative players? And can handle srt subtitle files.
Master123456789
Posts 237
Found a way to fix Kodi Player - now it works - thank you! :)
lawrencejmcook
Posts 742
That’s good news! Enjoy...
Page 1 of 1 (13 items) | RSS
