Dear forum
When I play a movie on my mac on VLC-player to my Beovision 11 via a HDMI-cable I get the surround-back sound on my BV11. When I use another player on my mac it is not a problem. What to do? I only have the tv-speakers and no surround setup. That is also why it is very strange.
Master123456789:Dear forum When I play a movie on my mac on VLC-player to my Beovision 11 via a HDMI-cable I get the surround-back sound on my BV11. When I use another player on my mac it is not a problem. What to do? I only have the tv-speakers and no surround setup. That is also why it is very strange.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I have also checked up on that. They are front left and right. When I use another player, example quicktime it is no problem. But I want to use VLC as it can add subtitles, the srt file
Nobody uses VLC player from mac to HDMI? ;-) ;-)
Master123456789:Nobody uses VLC player from mac to HDMI? ;-) ;-)
BeoNut since '75
try to test a blue ray or dvd movie :) I have just tried on my BV 8-40 - no problem, it worked - so it must be something on my BV11
Master123456789:I have just tried on my BV 8-40 - no problem
Master123456789:try to test a blue ray
I just received an update to VLC-player and now the sound on my BV11 is one front speaker and one back. I also tried with separate speakers - did not make any difference.
I am open till trying another mediaplayer. Kodi cannot be verified on my mac, it is from an "unidentified developer" - got other alternative players? And can handle srt subtitle files.
Found a way to fix Kodi Player - now it works - thank you! :)
