Linking mp3 player to beocenter 8000
This post has 5 Replies | 0 Followers
Maarten2300
Posts 9
Maarten2300 Posted: Tue, Sep 25 2012 3:36 PM
I have tried to connect mij mp3 player to mij beocenter by using the aux input but then the volume is very low. Does anybody knows how to solve this?
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Sep 25 2012 4:30 PM
I had this issue with a DIN to 4 RCA cable.
Even though it said aux-in left and right on the cable it was just labelled wrong.
Changing it to the ones labelled aux-out it worked.
Writing this to show it might just be a cable issue.
You need MP3 to AUX.
What kind of cable are you using?
THIS should work.
Ralf
Maarten2300
Posts 9
I have a 5 pins din connector to 2rca and than 2rca to mp3(3.5mm). Do you think it would make any difference when its is an direct
5pins din to mp3?
Maarten
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Sep 26 2012 9:18 PM
Yes I do - buy a cable from soundsheavenly (sponsor) it will work... If your system is working. Just a few bucks and no more wasted time ....
Maarten2300
Posts 9
allright I orderded one, i wil let it know if it makes a difference
Maarten2300
Posts 9
I received the cable and it works perfect, I think that the 2 wires from the jack goed to other pins on the connecter.
Page 1 of 1 (6 items) | RSS
