I have tried to connect mij mp3 player to mij beocenter by using the aux input but then the volume is very low. Does anybody knows how to solve this?
I had this issue with a DIN to 4 RCA cable.
Even though it said aux-in left and right on the cable it was just labelled wrong.Changing it to the ones labelled aux-out it worked.Writing this to show it might just be a cable issue.You need MP3 to AUX.
What kind of cable are you using?
THIS should work.
Ralf
I have a 5 pins din connector to 2rca and than 2rca to mp3(3.5mm). Do you think it would make any difference when its is an direct
5pins din to mp3?
Maarten
allright I orderded one, i wil let it know if it makes a difference
I received the cable and it works perfect, I think that the 2 wires from the jack goed to other pins on the connecter.
