Beosound Core wired to Beolab 5000 panels
This post has 6 Replies | 2 Followers
Rob
Germany
Posts 28
Rob Posted: Sat, Sep 1 2018 2:00 AM
Hi there all, if I wired up a BS Core directly to BL 5000 Panels would they switch on and what would be displayed on their screens? I’m assuming that i would theoretically be using a splitter cable from Steve. What would the UX on the App be like? I know freaky question. Smile Rob
elephant
AU
Posts 8,219
You’d see a picture of the Core
I have labelled my Core “20” to reflect the speakers it has attached, and to make Siri commands easier.
I don’t know that the App supports you having pictures of the attached speakers.
At least Apple’s HomeKit lets you do that sort of thing.
BeoNut since '75
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Rob,
Yes, this would work, you will see an image of the Core in the app, but you should be able to change this.  The cables need to be fully wired mk.2 versions (my splitters are also fully wired) - this will work fine except that the Core is not able to light up the displays on the speakers.
You would need:-
One RJ45 to twin Powerlink mk.2 Splitter: https://soundsheavenly.com/bang-olufsen/27-313-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html#/20-length-02m
Two Powerlink mk.2 cables: https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Rob
Germany
Posts 28
Rob replied on Sat, Sep 1 2018 8:04 AM
Thanks for the answers Yes - thumbs up
elephant
AU
Posts 8,219
elephant replied on Sat, Sep 1 2018 12:41 PM
Steve at Sounds Heavenly:
Just checked the latest beta and I cannot see how to do that.
BeoNut since '75
Posts 2,165
Hi elephant,
Good question!  I haven't tried the latest software beta, maybe one of the guys from the B&O software team can comment on how to change the icons displayed in the app on the new software?
Steve.
kallasr
Germany
Posts 2,562
kallasr replied on Sat, Sep 1 2018 2:27 PM
Rob:
BeoSystem 4 does not support Penta/Beolab displays. I guess the Core will be the same.
Ralf
Page 1 of 1 (7 items) | RSS
