BeoNut since '75
Hi Rob,
Yes, this would work, you will see an image of the Core in the app, but you should be able to change this. The cables need to be fully wired mk.2 versions (my splitters are also fully wired) - this will work fine except that the Core is not able to light up the displays on the speakers.
You would need:-
One RJ45 to twin Powerlink mk.2 Splitter: https://soundsheavenly.com/bang-olufsen/27-313-rj45-powerlink-compatible-splitter-new-powerlink-to-two-8-pin-din-powerlink-compatible-sockets.html#/20-length-02m
Two Powerlink mk.2 cables: https://soundsheavenly.com/powerlink-8-pin-din-connection/23-319-powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores.html#/9-length-18m
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Steve at Sounds Heavenly:you will see an image of the Core in the app, but you should be able to change this
Hi elephant,
Good question! I haven't tried the latest software beta, maybe one of the guys from the B&O software team can comment on how to change the icons displayed in the app on the new software?
Rob:and what would be displayed on their screens?
