Beomedia 5 questions
This post has 7 Replies | 0 Followers
kai
Posts 362
kai Posted: Tue, Oct 16 2018 11:57 PM
What can I do with a beomedia 5, I'm lucky enough to be getting one but I have an older system overture, lab 4000 and a few passive kits, what would people recommend is it worth pursuing putting into the system
frog
Camberley UK
Posts 624
frog replied on Wed, Oct 17 2018 6:54 PM
You’ll be able to use it for n.music and n.radio.
Griebel
Posts 416
Griebel replied on Thu, Oct 18 2018 8:08 AM
kai:
beomedia 5
This device does not exist. Did you mean BeoMedia 1 or BeoMaster 5?
Hiort
Sweden
Posts 2,895
Hiort replied on Thu, Oct 18 2018 11:29 AM
Griebel:
Could be a Beosound 5?
StUrrock
Posts 995
StUrrock replied on Thu, Oct 18 2018 6:15 PM
If it is indeed a solitary BeoMaster 5 then it is very useful in 2 ways;
1. to replace a defunct unit to make a beosound 5 function again.
2. On its own as a step to reach a cupboard.
Connected to any other electrical device, on its own, it makes a chocolate teapot look like a nobel prize winner for technology.
kai
Posts 362
kai replied on Thu, Oct 18 2018 11:49 PM
Its the one that came with the beosound 5, I know it has the same functions as the beomedia, and yes I will admit it was not the greatest device, it I could get a beosound 5 head unit it would make a lot more sense but I think they are to expendibe. Maybe the suggestion of using as step is not a bad thing lol, maybe see if I can sell it to someone that has a fault head unit :)
kai
Posts 362
frog
Camberley UK
Posts 624
frog replied on Sat, Oct 20 2018 5:12 PM
It works the same as a beomedia 1 in this format - just plug the bottom dvi cable into the tv (or beosystem) and configure it using the setup menus.
As mentioned, you can use it for n.music and n.radio - the music could be on the disk or on a Fileserve over dlna
Page 1 of 1 (8 items) | RSS
