Beocenter 2300 CD issue
mr_anders_son
sweden
Posts 1,710
mr_anders_son Posted: Thu, Dec 27 2018 9:04 AM
I know we have cover this issue many times before.
But I can not find the nearest answer for this.
When I press play on CD it spinns for 2 sec then stops.
Is it the only way to replace the laser unit??
thanx.
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
mr_anders_son
sweden
Posts 1,710
This type!?
https://www.ebay.co.uk/itm/CD-Laser-Pick-Up-for-Bang-Olufsen-B-O-Beosound-BEOCENTER-2300/302663807553?hash=item46782b3241:g:LMMAAOSwurVZkCAn:rk:8:pf:0
Peter
Siemianowice Sl., Poland
Posts 111
Peter replied on Thu, Dec 27 2018 12:07 PM
I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty.
Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
mr_anders_son
sweden
Posts 1,710
Peter:
I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty. Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
I have clean it.
And got it work....but when I change to Radio and back to CD it spinns 2 sek then Stop. If I just touch the lens, not glas) it works againHuh?
Page 1 of 1 (4 items) | RSS
