I know we have cover this issue many times before.
But I can not find the nearest answer for this.
When I press play on CD it spinns for 2 sec then stops.
Is it the only way to replace the laser unit??
thanx.
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
This type!?
https://www.ebay.co.uk/itm/CD-Laser-Pick-Up-for-Bang-Olufsen-B-O-Beosound-BEOCENTER-2300/302663807553?hash=item46782b3241:g:LMMAAOSwurVZkCAn:rk:8:pf:0
I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty.Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
Peter:I keep this repeating but before laser replacement you should be sure that nether laser lens nor CD are dirty. Someone said that if glass in your cuppoard becomes dirty after some time the same happens to you laser lens.
