My setup consists of 5 zones.
1 independent zone : BV Avant NG / Beosound moment / BL20s
4 zones connected to a Crestron multiroom AMP.
I am trying to connect the B&O steaming source so it can play in the whole house. Would connecting a WISA receiver 1 using this cable to the line in of the AMP do the job ?
Thanks.
What you get out from Moment using that cable is (as I understand it) is a line level signal, so you need a line level input in your amplifier. I assume it could work that way.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
The moment and the AMP are not in the same room that's why i thought a receiver 1 might help. But how to power it on?
Sorry if i have zero experience with powerlink.
The Receiver 1 made to wirelessly receive a Powerlink connection using the WISA standard. Would you use Moment to transmit?
Where you thinking of connecting the received to Cretron?
I doubt that its possible.. Also, this WISA connection will not work between different rooms.
Hi IA64,
Yes, you can take a line output from a Powerlink socket of the TV to the Crestron system with this cable - you can assign this Powerlink socket to any two audio channels (eg. front left/right) and also assign them as fixed line level volume if you wish within the TV menu.
If you decide to use a wireless link, then please note that you will need a Transmitter 1 plus two Receiver 1s for stereo sound, as each Receiver 1 is mono only.
Please feel free to get in touch via my sponsor link below and I will be happy to help you to find the best way to get everything working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
