Will this work ? Connecting Beosound moment to AVR.
IA64
Posts 135
IA64 Posted: Tue, Nov 20 2018 6:15 AM
My setup consists of 5 zones.
1 independent zone : BV Avant NG / Beosound moment / BL20s
4 zones connected to a Crestron multiroom AMP.
I am trying to connect the B&O steaming source so it can play in the whole house.  Would connecting a WISA receiver  1 using this cable to the line in of the AMP do the job ?
https://soundsheavenly.com/bang-olufsen/65-365-rj45-powerlink-compatible-to-twin-phono-cable-output-from-new-bo-devices-to-amps-receivers-etc.html#/length-5m
Thanks.
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Nov 20 2018 7:18 AM
What you get out from Moment using that cable is (as I understand it) is a line level signal, so you need a line level input in your amplifier. I assume it could work that way.
IA64
Posts 135
IA64 replied on Tue, Nov 20 2018 7:59 AM
The moment and the AMP are not in the same room that's why i thought a receiver 1 might help. But how to power it on?
Sorry if i have zero experience with powerlink.
IA64
Posts 135
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Nov 20 2018 8:51 AM
The Receiver 1 made to wirelessly receive a Powerlink connection using the WISA standard. Would you use Moment to transmit?
Where you thinking of connecting the received to Cretron?
I doubt that its possible.. Also, this WISA connection will not work between different rooms.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi IA64,
Yes, you can take a line output from a Powerlink socket of the TV to the Crestron system with this cable - you can assign this Powerlink socket to any two audio channels (eg. front left/right) and also assign them as fixed line level volume if you wish within the TV menu.
If you decide to use a wireless link, then please note that you will need a Transmitter 1 plus two Receiver 1s for stereo sound, as each Receiver 1 is mono only.
Please feel free to get in touch via my sponsor link below and I will be happy to help you to find the best way to get everything working.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (6 items) | RSS
