Wrong signalcable?
VU meter only works when recording!
In record mode, with record level turned up, try inserting a small metal pin (bent paperclip or similar) into theDIN socket at the back one pin at a time.Two pins should give a deflection on the left and right meters respectively.If this is fine your cable or signalsource is at fault.
If not fine, check the record/playback switch.
Hi Martin, thanks for your interest. Only the keft VU meter works. The right unfortunately not. The recording is therefore only 1 speaker. Is that also a cableproblem?
Greetings Fred
Check the record/playback switch.It has many contacts, and is prone to oxidation, particularly if not used regularly.
