Beocord 1900 cassette deck
kunsf00
Posts 81
Silver Member
kunsf00 Posted: Sat, Dec 8 2018 2:14 PM
Hallo, onlangs een Beocord 1900 cassette deck gekocht. Het afspelen op de Beomaster 1900 werkt perfect. Echter er is een probleem met opnemen. Hij neemt namelijk niet op. De VU Meters slaan ook niet uit. Wat kan het probleem zijn? Weet iemand op het forum misschien de oplossing?
Groeten, Fred
Hello, recently bought a Beocord 1900 cassette deck. Play on the Beomaster 1900 works perfectly. However, there is a problem with recording. He does not work. The VU Meters also do not work. What can be the problem? Does anyone know the solution on the forum?
Greetings, Fred
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 8 2018 3:09 PM
Wrong signalcable?
Anders Jørgensen
Denmark
Posts 350
VU meter only works when recording!
kunsf00
Posts 81
Silver Member
kunsf00 replied on Sat, Dec 8 2018 10:50 PM
Yes I Know, but the VU Meters don’t work while recording.
Dillen
Posts 13,191
Dillen replied on Sun, Dec 9 2018 10:32 AM
In record mode, with record level turned up, try inserting a small metal pin (bent paperclip or similar) into the
DIN socket at the back one pin at a time.
Two pins should give a deflection on the left and right meters respectively.
If this is fine your cable or signalsource is at fault.
If not fine, check the record/playback switch.
kunsf00
Posts 81
Silver Member
kunsf00 replied on Mon, Dec 10 2018 9:39 AM
Hi Martin, thanks for your interest. Only the keft VU meter works. The right unfortunately not. The recording is therefore only 1 speaker. Is that also a cableproblem?
Greetings Fred
Dillen
Posts 13,191
Dillen replied on Mon, Dec 10 2018 11:50 AM
Check the record/playback switch.
It has many contacts, and is prone to oxidation, particularly if not used regularly.
Page 1 of 1 (7 items) | RSS
