Hello All,
I'm hoping I can receive some recommendations. Following a little research I understand spare parts are very limited for the Beolab 1 speakers. I have an issue where, after about 15-20mins of use the speaker develops a crackling/interference noise like the speaker has loose connection. I have swapped out the speaker for another and that's fine; so confident it's the speaker. I'm happy to disassemble the speaker but not sure what I'm looking for. Any help would be gratefully received. Many thanks,
Merry Christmas All.
Anyone?
If you haven't any luck, you can always send it over for repair.
Several weak points including the defect will be solved.
Send me a pm when interested.
Thanks beobuddy, appreciate the offer but concerned with sending such a big item to Denmark. I was looking for technical advice on common issues and some direction on what to check/replace.
Hopefully, someone will be able to support me.
Best wishes from the UK.
