BEOLAB 1 ACTIVE LOUDSPEAKERS - Defective
This post has 4 Replies | 3 Followers
mark1
Posts 4
mark1 Posted: Sat, Dec 22 2018 10:11 AM
Hello All,
I'm hoping I can receive some recommendations.  Following a little research I understand spare parts are very limited for the Beolab 1 speakers.  I have an issue where, after about 15-20mins of use the speaker develops a crackling/interference noise like the speaker has loose connection.  I have swapped out the speaker for another and that's fine; so confident it's the speaker.  I'm happy to disassemble the speaker but not sure what I'm looking for.  Any help would be gratefully received.  Many thanks,
mark1
Posts 4
mark1 replied on Wed, Dec 26 2018 2:47 PM
Merry Christmas All.
Anyone?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, Dec 26 2018 4:55 PM
If you haven't any luck, you can always send it over for repair.
Several weak points including the defect will be solved.
Send me a pm when interested.
mark1
Posts 4
mark1 replied on Wed, Dec 26 2018 9:18 PM
Thanks beobuddy, appreciate the offer but concerned with sending such a big item to Denmark.  I was looking for technical advice on common issues and some direction on what to check/replace.
Hopefully, someone will be able to support me.
Best wishes from the UK.
mark1
Posts 4
Page 1 of 1 (5 items) | RSS
