i would simply know if i can do "Menu" on this terminal ?
it has no "menu", no shft, but has "control" "tune", "step", ....
i tried some combinations but nothing worked.
Thanks a lot
Zazou
It seems that you have an old Video Terminal,rather than a Beolink 1000?
They were supplied with the LX25/2800 tv's,and as there was no onscreen menu with these tv's,there is no function for it via the remote control.
The later LX25/2802 tv's however,did have a menu system,and came with the Beolink 1000 remote control,which became the defacto universal B&O remote control for many years.
Nick
(As above) I think he is talking about the BL1000 predecessor discussed in this thread: https://archivedarchivedforum2.beoworld.org/forums/p/38215/317414.aspx#317414
There was the V Terminal, A terminal and AV terminal.
I think in this situation, if you need MENU, I would look for a second hand BL1000.
effectively, Guy, you are right. It's exactly the remote shown in the thread you mentioned.
Thanks both for your reply.
I have an old BV3 to give, and i cannot give it without a remote.
So i thought, i could give the Video terminal, but if it cannot do "Menu", i cannot give it.
i have another normal BL1000, so i have to give this with the BV3.
Regards from Strasbourg / France
