Wanted: output cable for Beocord 6500/7000
This post has 3 Replies | 2 Followers
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Fri, Jan 11 2019 12:28 PM
Hi All,
still looking for the output cable with 5-pin DIN attached for my Beocord 6500.
BC5500 or BC7000 cable will also work.
if you habe one please send me a PM
cheers
ALF
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi ALF,
Please feel free to get in touch via my sponsor link below if you can't locate a cable via another Beoworlder and I will be pleased to build a cable for you.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Tue, Jan 15 2019 1:38 AM
Hi Steve,
once again thank you for your reply.
not sure whether there’s a misunderstanding or not ?
the cable or wire-harness I am chasing is the hard-wired cable with one DIN plug attached connecting to a BM while the other end is hard-wired directly  onto the main board of the BC6500 - in other words it is non-removable like a interconnect but like the powercable.
regards
ALF
Posts 2,165
No problem ALF,
I can build a replacement cable for you to solder to the board inside the Beocord if you can't find an original cable from another owner.
Steve.
Page 1 of 1 (4 items) | RSS
