Hi All,
still looking for the output cable with 5-pin DIN attached for my Beocord 6500.
BC5500 or BC7000 cable will also work.
if you habe one please send me a PM
cheers
ALF
Hi ALF,
Please feel free to get in touch via my sponsor link below if you can't locate a cable via another Beoworlder and I will be pleased to build a cable for you.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Hi Steve,
once again thank you for your reply.
not sure whether there’s a misunderstanding or not ?
the cable or wire-harness I am chasing is the hard-wired cable with one DIN plug attached connecting to a BM while the other end is hard-wired directly onto the main board of the BC6500 - in other words it is non-removable like a interconnect but like the powercable.
regards
No problem ALF,
I can build a replacement cable for you to solder to the board inside the Beocord if you can't find an original cable from another owner.
