Hi everyone,
After a very long break, I have started to add new videos to YouTube. Here is the first one, explaining the options for upgrading a classic B&O audio system to play wireless streaming music from your phone:-
https://youtu.be/FpjRnG2Iryw
If there are any cabling videos that you would like to see, please let me know!
Next video due this week: Re-purposing a Beolab 3500 as a stand-alone TV speaker/iPod dock.....
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Well done, Steve.
Good one Steve! Your Mini Jack-DIN cable has made my friend the happiest!
Just wondering why you did not mention the B&O streaming devices (Essence, Core...), that - in the same way - can be connected to older B&O gear?
Hi MM,
Good point! I tried to cover the most popular options, but I probably get asked about Airport Express or Sonos 20 times for every 1 time that someone asks about Essence or Core. I have added that to my list of future videos to make.....
Today, I have collected a Beolab 3500 mk.1 from B&O Leicester to film my next video guide, which will be how to use Beolab 3500 as a stand-alone speaker with a phone, computer or non-B&O TV, no B&O system required.
Any more ideas for video guides that I should cover?
Steve at Sounds Heavenly:Any more ideas for video guides that I should cover?
Steve at Sounds Heavenly: Any more ideas for video guides that I should cover?
Maybe this - is it possible to use the Aux for connecting an external source........when it is already in use for a converter/1611 to ML?
Or - how to use an Active Link box for an external device locally (the PC connection).
Thanks mbolo01 and MM,
Yes, I already have using the Line input of Beolab 6000/8000 on my list of videos to make this month
Using the Aux connection of a 2300/2500 system when a 1611 Converter is connected is straghtforward, you just need a 7 pin Splitter to share the socket:-
https://soundsheavenly.com/bang-olufsen/11-312-7-pin-aux-splitter-dual-aux-tape-input-sockets.html#/20-length-02m
The PC connection to the Beolink Active is also possible via a specially wired cable:-
https://soundsheavenly.com/link-input/68-2213-minijack-ipod-pc-etc-to-beolink-active-pc-socket.html#/4-length-3m/59-beolink_active_version-type_163x
I will look at adding these to the list of videos very soon!
