Beolab 50 - Adjust acoustic lens
Oasis
Posts 49
Oasis Posted: Sun, Mar 10 2019 4:13 AM
How does one adjust the width of the Acoustic lens on the BL 50 from narrow to wide?
and can you preset with particular function eg listening music vs watching TV?
Beofile7
Posts 150
Beofile7 replied on Sun, Mar 10 2019 10:25 AM
The acoustic lens is controlled via the B&O app. Profiles are set up for your preferences, if you can get it to work!
Millemissen
Flensborg, Denmark
Posts 14,680
This video might also give you some hints
https://youtu.be/Sb2Vu12hqD4
If you are already familiar with the basics, just go to the last part, where the presets are mentioned.
Also see the following videos in the same playlist.
Page 1 of 1 (3 items) | RSS
