How does one adjust the width of the Acoustic lens on the BL 50 from narrow to wide?
and can you preset with particular function eg listening music vs watching TV?
The acoustic lens is controlled via the B&O app. Profiles are set up for your preferences, if you can get it to work!
This video might also give you some hints
https://youtu.be/Sb2Vu12hqD4
If you are already familiar with the basics, just go to the last part, where the presets are mentioned.
Also see the following videos in the same playlist.
