Hello
My Beomaster 5 HDD is broken.
BO in Geneva is asking for 800 E (!) to repair. This is almost as much as a complete 2nd hand beosound 5.
Would you know any independ shops who could do it for less ?
I'm near Geneva so Swiss or French shops welcome.
Christophe
Find your local P C repair shop.
Ask them to recover the HDD content and clone the disk if they can.
I assume you have a mechanical failure and not a software corruption failure.
Should be significantly cheaper
You should be able to do it yourself by swapping out the disk and using the Beomaster 5 software tool to re-create the disk. You’ll lose the music, but if you connect the old one to a PC, you may be able to get the E:(data) volume and copy the music from there.
Hi Christophe,
I'm also based in Switzerland (between Geneva and Lausanne), I can help your with your BeoSound 5 hard drive.
Don't hesitate to contact me !
Regards.
